What kind of oil filter wrench do you use?
Old Feb 4, 2006 | 03:14 PM
2manytoys's Avatar
Default What kind of oil filter wrench do you use?
Prozak take your filter to the auto parts store and see if they can match a cup to it. This will make life easier.
Old Feb 4, 2006 | 03:16 PM
zerowick's Avatar
As long as you don't have gorilla hands lol. I used a pair of channel locks to remove mine and like he said coat with a film of oil on the gasket and hand tighten.
yup, big channel locks, even then it's a pain getting them in the right position, but loosens it enough to finish by hand. just make sure to only tighten new one BY HAND ONLY as already mentioned.
Old Feb 4, 2006 | 03:19 PM
zerowick's Avatar
no room for a cup, side of filter is too close to motor, can barely slip a band wrench in there, probably the best way if you can get a small enough band wrench, mine are too big so the channel locks do the trick.
Old Feb 4, 2006 | 06:39 PM
encorebilly's Avatar
Polaris sells a filter wrench for that unit,forget the part #.I went to auto store and bought the cup type but it was very close,however I managed.Next time I change it I will cut down the length of the cup with hacksaw and I will be fine.
Old Feb 4, 2006 | 06:43 PM
  #15
[quote]
Polaris sells a filter wrench for that unit,forget the part #.I went to auto store and bought the cup type but it was very close,however I managed.Next time I change it I will cut down the length of the cup with hacksaw and I will be fine.[/q
Just checked my repair manual for my 05 700efi,Oil filter wrench(cup style) part # PV-43527.But as I said you could cut down a Wal-mart cup.
  #16
ProZac's Avatar
I would love to find one from Polaris that would fit.
Old Feb 4, 2006 | 09:48 PM
  #17
caper700's Avatar
There is 2 kinds of filter sockets fit the filter for your bike. One is made of cast and one is plastic. The one that has the clearance along side the motor is the plastic one. I have one that I got fro my dealer and it looks like it's made from ABS material. If tyou don't have any luck let me know and I'll give you a part #
Old Feb 4, 2006 | 10:17 PM
  #18
zerowick's Avatar
I got the one from Wal-Mart and that's why I didn't think it fit. didn't work so I brought it back, never though about modifying it, maybe I was too hastey. is it a metal cup that fits?
Old Feb 4, 2006 | 10:31 PM
  #19
garrett5462's Avatar
an oil filter is only supposed to be a half turn after the gasket is touching.
Old Feb 4, 2006 | 10:41 PM
  #20
zerowick's Avatar
never saw one that said 1/2 turn, although that may be enough, the ones I have used usually say 3/4 - 1. they probably don't want the liability of it falling off.
