What kind of oil filter wrench do you use?
Old Feb 4, 2006 | 11:03 PM
  #21
Fireslayer's Avatar
Default What kind of oil filter wrench do you use?
Prozac, I just went down to check to see if I had a cup type filter wrench that would work on the SP700EFI and I found one. It is the same one I use on my wifes Toyota RAV 4 (2005 AWD Model). I don't recall where I got it right off; (possibly NAPA / Advance Auto?) The name and number in the inside of it is as follows; CAL-VAN 785 USA. Maybe someone at your local auto parts or Toyota dealership can cross the number over to their brand if they don't have it by this number. It is a stamped steel cup socket which will slip on the filter without any modifications. You will also need a 3/8" drive rachet and a 3" long 3/8" drive extension. With these three tools this becomes a simple task. Having the correct tools for the job makes all the difference. This one is nothing to get access to compared to some of the stuff out in the automotive world. Hope this helps.
Old Feb 4, 2006 | 11:41 PM
  #22
2manytoys's Avatar
Damn I work for Toyota and was just going to say try the small cup for a Toyota.
Old Feb 5, 2006 | 02:05 AM
  #23
mistertinker's Avatar
did you try a pair of oil filter pliers? if those do not work go get a napa nylon strap filter wrench. it will definetly remove it. i dont use those sockets anymore had a problem of them getting stuck on the end of the filter.
Old Feb 5, 2006 | 02:11 AM
  #24
strap wrench<a target=new class=ftalternatingbarlinklarge href="http://
http://doityourself.com/store/u584128.htm">filter pliers</a>
Old Feb 5, 2006 | 02:13 AM
  #25
ProZac's Avatar
thanks for all the replies. I'm gonna see if I can find the small one for a toyota
Old Feb 5, 2006 | 07:11 AM
  #26
tstroker's Avatar
got a filter wrench at advance auto parts, metal, works great on pure one, p14610 and p14612's, needs to be tapped gently onto polaris oem filters, forms the can to the wrench, and off they come....
Old Feb 5, 2006 | 08:00 AM
  #27
wayout's Avatar
Originally posted by: garrett5462
an oil filter is only supposed to be a half turn after the gasket is touching.
3/4 of a turn...
Old Feb 5, 2006 | 03:49 PM
  #28
gunman457's Avatar
Large Channel Locks work great for getting off oil filters. When you put the new filter on, oil the seal and the filter should be only one hand tight(your weak hand). Do not use filter wrench to install. The oil filter will tighten up as your seal on the filter will expand from the oil.
Old Feb 5, 2006 | 06:49 PM
  #29
WGMARQ's Avatar
I used the cup one from WalMArt and used a bench grinder to take down that outside lip so it will slide on. The was only needed for the factory installed filter. I don't reinstall it too tight.
Old Feb 6, 2006 | 07:53 AM
  #30
kj330's Avatar
You never want to use an oil filter wrench on an oil filter,( unless your fingers cant touch the filter) to install a filter all you need is your clean fingers. .5-.75 of a turn after the gasket touches..In all my years of working on cars, construction equip.,and small engines I have never seen one that you cant touch. They design them for that reason. The heat of the motor causes the final seel..
