No lights or instrument cluster
I have a 2003 Sportsman 400 and I have lost my lights and instrument cluster. My winch still works and I can turn the ignition on and pull start but it will not start with the ignition key. Has anyone ever had this problem? It all started a few months ago when I noticed my lights flickering off and on when I applied the brake (on the handle bar). It did this several times until finally it they went off for good. Any help would be appreciated before I give in and take it to the dealer.
six 8
i had a problem with the pod cluster going out when you turn to right and when i turned back it would come back on. I took the pod off and front plastic and started looking for loose wires. in my pulling wires i got the pod to go off and the head lamp when off to. i found that the brown wire going to head lamp blub was boke in the harness i ran another piece of wire and every thing works fine. the brown wire feed power to head lamp and pod assy.
I had a similar problem on my scrambler, turned out to be the run switch on the left side of handlebars, try playing around with that switch with key switch turned on. I lost lights, starter, awd and cooling fan but would start with pull starter and ran fine.
