My trailblazer trans.....HELP ME!!!!!
Old Feb 11, 2006 | 12:49 AM
Gurney's Avatar
Default My trailblazer trans.....HELP ME!!!!!
Ok i cracked the right side of the trans......the trans is still good and all i need is the front half of the case.....i got the model number......its 1341274 and i also got the serial number........its 400-11467......is there anyone out there that can help me? what bolts hold it in the wheeler? I NEED HELP!!!!!!!
Old Feb 11, 2006 | 07:56 AM
ftwflh's Avatar
Best bet is to get you a Polaris manual to help you withthis job.It is very simple to get out but you need to take the rear plastic,clutches and covers off and one of the bolts out of the tranny case to get it out.The manual has good diagrams of which bolt and other stuff that neds removed.
Old Feb 11, 2006 | 10:05 AM
Gurney's Avatar
i have the rear plastic removed.....the pipe removed all the bolts i can see are removed......its almost out but theres 1 bolt i can find 2 remove....can i just buy the front half?
Old Feb 11, 2006 | 10:22 AM
scootergptx's Avatar
Supersock
Hired Gun!
Ftwflh is right about the manual. You may be able to get some help from the parts break down. Got to Polaris , and in the upper right corner, click on riders. You'll get a drop down menu, and click on manuals and parts. The parts diagrams are free and you can download and save them. That may help with the one bolt.
Check ebay for the case and a manual.
Hope you're running soon
Old Feb 11, 2006 | 04:16 PM
ftwflh's Avatar
You can get the tranny halves but they are $199.99 each and while you have it apart at least put in a new silent chain and check the shift forks.
Your best bet may be to look on ebay for a used tranny.One from a 2000-up Trailblazer,325 Trailboss,330 Tailboss or 2wd 400 or 500 Scrambler will fit.
Old Mar 4, 2006 | 12:55 PM
jthomas92277's Avatar
I have cracked my tranny as well I am looking too rebuild I have the right side brand new ( the side with the chain) part# 3233683 I need the other half if you are going to be gettiing a whole tranny too replace it wich run about 200 on ebay and your Left hand side is not cracked I would like to purchase that side from you.
I puchased the other half a while back before I broke my case becuase I was told that the side withht he chain breaks when the chain goes it just so happend that both sides cracked and I hhave noot wanted to part with another 200.00 foor the other side, or waiste the other side by purchasing a used whole tranny.
My email is jthomas92277@gmail.com maybe we can make this cheaper for the both of us.
Thanks
Jay
Old Mar 4, 2006 | 09:05 PM
ftwflh's Avatar
Thanks
Jay
Good luck ......I WAS IN THE SAME BOAT AND GOT A COMPLETE TRANNY FOR LESS THAN THE PRICE OF A SIDE.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
