gas cap in the way
Old Feb 12, 2006 | 08:34 PM
brownweiser's Avatar
Default gas cap in the way
i have a 2000 sportsman, when im riding and take a sharp right the key hits the gas cap and shuts the machine down. makes for good times going down a step winding hill. is there anything i can do? can i reposition the ignition?
thanks
Old Feb 12, 2006 | 08:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that used to happen to me when i had a key chain or anything esle beside the key only. now i just use the key so not to have it hit and shut off.
Old Feb 12, 2006 | 09:03 PM
DSLKSL's Avatar
Yep...he's right it's your keys.
It's happened to all of us (Or maybe just me)
Old Feb 12, 2006 | 10:59 PM
JCDEYO25's Avatar
I just use the ignition key by itself but I also have it connected to one of those rubber coiled keychains that I hook to the handlebar just incase for some reason the key comes loose,which shouldn't happen, but it's just an extra precaution that I take.....
John
Old Feb 12, 2006 | 11:57 PM
thanks guys, but im just using the key alone and it's still hitting the cap. i will try to adjust the ignition box to see if i can free up some space?
Old Feb 13, 2006 | 12:56 AM
Polaris500HO4x4's Avatar
hmm has it been rolled hard
Old Feb 13, 2006 | 11:40 AM
dontgetbehindme's Avatar
This may be a stupid ? but is the cap tighting down all the way? Mine does the same thing but its due do a key chain. Be sure all the screws are in the pod.
Old Feb 13, 2006 | 12:34 PM
it has'nt been rolled. not to hard[img]i/expressions/face-icon-small-happy.gif[/img] and the gas cap is tight first thing i checked.
thanks guys
Old Feb 14, 2006 | 05:00 AM
polarisbear500's Avatar
this happened to me and i found that the bottom part of the headlight pod was sagging a little. if you will make sure all 3 of the screws that hold the top and bottom together are there that will help. if that doesn't fix it, i loosened the 2 handlebar bolts that are inside the pod and picked up on the bars a little to raise it up. good luck
Old Feb 14, 2006 | 11:42 AM
thanks polarisbear, im going to muck around with it today
