jet kit for predator 500
Old Feb 16, 2006 | 11:47 AM
sportsman40005's Avatar
Default jet kit for predator 500
I currently run it without any disc.I don't know if this is best or not,but it sounds stronger.I was just looking for a small simple mod. that would give a little more pep.The unit is run on trails ,mud,hill climbing ,etc, no racing.
thanks
Old Feb 16, 2006 | 12:19 PM
Hoopie's Avatar
I tried mine with no disks and it made it louder and slower! especially on the low end. It needs the back preassure i think. I was better off with 12 disks.
Old Feb 16, 2006 | 02:53 PM
Bradracer18's Avatar
Where I run the race modded carb, I don't need any disks......otherwise, I could see them used. Personally, the turn down tip is what the "big boys" are running. I'll someday, graduate to it I suppose.
But seriously though guys, if you want a fairly simple mod, get the first carb mod by nicholas cycle. This is a great mod, no joke!! Then, you can also upgrade to a clamp on filter....or atleast a drop in. But, bar none, the carb mods are the way to go!!! Check out www.predatorowners.com there are some reviews on the carb mods on there, I believe in the modifications section.
Old Feb 22, 2006 | 11:29 PM
I haven't been on the site for a while.Does the turned down tip give any more power ? If so, where to buy & cost ?Does it bolt on to the wb pipe ?
Old Feb 23, 2006 | 09:21 AM
  #15
I believe rocky mountain atv used to have them......If not, you might try white brothers website(don't know it)......and if that fails, try nicholas Cycle(www.nicholascycle.com)
The tip is believed to give power due to the correct amount of back pressure it gives. It seems to give the pred a bit more torque....this is after you get the nicholas cycle carb mods though, that it helps. I highly suggest them, as a great performance upgrade. Also, if you decide to get them, talk to those guys about a clamp on twin air filter....this is about the best intake/carb set up you can have(and still have the stock carb). Call them up, and talk to Wes or Jeff, very nice guys to deal with, and very knowledgable about the pred.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
