How hard is it to install a Dayco Belt
Old Feb 20, 2006 | 05:45 PM
bigred500's Avatar
Default How hard is it to install a Dayco Belt
You guys that have installed the Dayco belts. How hard is it, do I need some special tools, do I need to buy a new gasket for the clutch cover? Any specifics will be helpful.
Old Feb 20, 2006 | 06:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its the same as changing a polaris belt. no special tools needed. just basic like 3/8 or 10 mm socket w/ extenios i beleave. just pry the secondary clutch apart going back in forth and sperate the sheeves. slid the old off and new on same way. it will take a little strength.
Old Feb 20, 2006 | 08:01 PM
2manytoys's Avatar
You dont need to even pull the clutch apart. Once you get the cover off all you need to do is pull the top of the belt twards you and roll the clutch clockwise and the belt roll right off. To install it just put it on the primary and roll the belt on the top of the secondary in the same direction. Very simple.
Old Feb 20, 2006 | 08:57 PM
bigred500's Avatar
So It's kind of like just putting a chain back on a bicycyle.
Old Feb 21, 2006 | 12:24 AM
scrammersam's Avatar
yep its one of the easiest things to do
Old Feb 21, 2006 | 12:16 PM
dontgetbehindme's Avatar
You may want to scuff up the clutches with a wire brush before you put on the new belt to remove any glazing on the clutchs. The dealer recommended it and also the heel clicker kit also sayed the same. You don't want to get it real rough get a once over should be fine.
Old Feb 21, 2006 | 01:02 PM
bigred500's Avatar
How much of the plastics did ya'll take off? Do ya'll just take the floorboard loose or did ya'll just go ahead and take the floorboards and fenders completely off?
Old Feb 21, 2006 | 02:47 PM
SPORTSMAN70003's Avatar
Just take you floorboard loose so you can get the belt cover off.
Cummins Driver
Sep 11, 2019 01:22 PM
Jazperman
Aug 7, 2016 08:12 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
