polaris belt question
Old Mar 14, 2006 | 10:54 PM
TJ700's Avatar
Default polaris belt question
Originally posted by: Jmpmastr82
If you are going to replace your belt use a dayco belt. They are alot tougher than the Polaris OEM belt.
a dayco will last longer, but it wont grip like an OEM belt.
mine is much more torquey with a polaris belt.
ive been told the same thing by the yamaha gang.
dayco will last longer if you arent into max performance, IMO.
at 2200 miles, if its on the original belt, give her a change out for the peace of mind.
steep hill id keep it in low and it shouldnt ever slip a belt, unless you have a passenger or something.
good luck.
Old Mar 16, 2006 | 10:11 PM
Sherlock's Avatar
i recently was going accross a field in deep snow and burnt up a belt. first it started smoking white smoke and then it was fine for a day then it finally blew in the middle of a different field. took it to the dealer and they said it was abuse and wouldnt give me a new one. i used a dayco belt and gained 4 mph on top end and a noticeable amount of mid range.
Old Mar 16, 2006 | 10:29 PM
TJ700's Avatar
those are really nice gains.
did you test a new polairs belt vs the dayco belt, or was this your worn belt vs the dayco?
Old Mar 16, 2006 | 10:31 PM
Sherlock's Avatar
just the old belt. i could only get around 53-54 out of it with the polaris belt. now in the 57-58 range by gps.
Old Mar 19, 2006 | 08:03 PM
  #15
sportsman40005's Avatar
Can you tell us (or me) where one would get a dayco belt ?
thanks,
ken
Old Mar 19, 2006 | 09:56 PM
  #16
TJ700's Avatar
thanks,
ken
ebay is probably the best bet on that one.
autozone stocks some atv parts, but they carry kelly belts, not dayco. not even sure if they deal with dayco. cant hurt to check.
good luck.
Old Mar 19, 2006 | 10:04 PM
  #17
Sherlock's Avatar
i got mine at the local Arctic Cat dealer.
Gtsordo
Jul 13, 2015 10:38 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
