Scrambler choking
Old Mar 1, 2006 | 05:31 PM
Russ136's Avatar
Default Scrambler choking
I just bought an 03 scrambler 500. When starting naturally you have to pull the choke out to get it to start. However the idle speed does not match the choke setting. It is way to rich for the idle speed. You can keep it running by using the throttle. It will smoke from the over rich fuel at this point. It will idle fine after it warms up. My wifes old 300 bayou will respond with idle speed and choke properly. One hand operation , no blipping of the throttle needed. This atv has a HSP clutch kit, pipe ,fmf megamax, air box mod and jet kit. I posted the 500 knocking on both 500's i bought off of ebay. Thanks for all the replies and putting me at ease about the tapping noise. This machine is awsome. Does anyone know how to make it idle up when choking.
Old Mar 1, 2006 | 08:30 PM
ftwflh's Avatar
Check your valves sounds like you may have a tight exhaust valve.
Old Mar 1, 2006 | 09:02 PM
Russ136's Avatar
Not the valves. Adjusted/checked my self. Actually they did not need any adjustment they where at .007and.006. The other 2002 scrambler 500 that I bought does the same thing. I think that enrichens the fuel via secondary carb slide/plunger. Is there any mechanical movement of the throttle. Is the jet kit or float level resonsible. Is there a way to adjust the choke idle or is it a live with thing.
Old Mar 1, 2006 | 09:49 PM
ftwflh's Avatar
Do you know what type of airbox mod you have?THe CV carb needs a certin amount of vacum to operate.
My 500 doesnt rev up with the choke on either just stays running until it is warm enought to run without the choke.Once you see how these act and work you will see they are pretty trouble free machines.
Old Mar 2, 2006 | 11:04 PM
jhama78's Avatar
Could you do me a favor and count how many discs are in your muffler? Thanks a bunch
-j-rOd
Old Mar 3, 2006 | 10:27 AM
Pete1818's Avatar
yeah, I will try dear -j-rOd, if you tell me how and why...
Pete
Old Mar 3, 2006 | 10:46 AM
jhama78's Avatar
I just got an FMF mega max for my scrambler and was wondering what everybody else is running so far as how many discs on the outlet of the silencer... if you could count the individual discs held on by the 6 screws that are bolted to the back of the muffler Id greatly appreciate it.
-j-rOd
Old Mar 4, 2006 | 01:22 PM
Russ136's Avatar
it looks like 6 or 7 discs. Does your choke and idle speed work properly.
exmotocrosser
Sep 13, 2019 06:12 AM
wrencher82
Sep 30, 2015 04:27 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
