CARB HELP!!!!!!
Old Mar 2, 2006 | 07:55 PM
Mudcruiser250's Avatar
Default CARB HELP!!!!!!
DO YOU GUYS KNOW IF THERE IS A BIGGER CARBERATOR FOR THE TB 250, THAT WILL FIT THE STOCK AIRBOX, IF THERE IS COULD YOU POINT ME INTO THE RIGHT DIRECTION THANK YOU
NIC P.S WHAT WILL THIS DO TO THE BIKE I ALREADY HAVE THE HPD PIPE AND CLUTCH KIT, AND A K&N W/ RAZR2'S ON IT. THANKS AGAIN NIC P.
Old Mar 2, 2006 | 09:04 PM
2manytoys's Avatar
Mudcruiser,
First off turn your caps off. You can get a carb from a scrammy 400 to work. It will fit the stock intake and airbox. You will need to use some of the parts from your 250 to make it work. You can usually find the scrammy carbs on ebay for about $30-$50. Why do you want a bigger carb? Tha gains with a bigger carb are minimal. You would be better off getting a good port job. The port job will give you the biggest power increase. But if you are not mechanicaly inclined the carb would be the easiest thing to do.
Old Mar 2, 2006 | 11:55 PM
16polaris's Avatar
Call Rick Ritter or HPD, they both deal with ALOT of carbs, they can get you set up with the right carb and jets for your needs.
Old Mar 3, 2006 | 01:49 AM
Polaris500HO4x4's Avatar
yes ive heard many good things about the work that rick ritter does
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
