HI temp Exhaust Paint?
Rust-Oleum gloss black says 150 degrees but I use it on every exhaust system I have painted and it hold up for 2 years with exhaust temp hitting 1325 degrees. It is on the Bubba Bike below and still on.
Cummins Tools sells it for $1.00- $2.00 a can.
You can also wrap your pipe in chrome heat tape and increase flow velocity and performance.
good luck
good luck
IF you realy want to cut the heat send the pipe out and have it cremic coated. this should create about 300-500 degree cut in surface temp after that is done wrap the pipe in the thermal tape. When I upgrade to the 800 header I'm going to do both becasue I don't like baking my parts.
#17
Originally posted by: watzupdog
So does the spray reduce heat build up.
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
