MAGNUM 325 ADJUSTING VALVES?
Old Mar 4, 2006 | 08:01 PM
ESCAVADER's Avatar
Default MAGNUM 325 ADJUSTING VALVES?
Just finishing spring maintanance on my magnum.Oil and filter,tranny oil differential oils,geaybox,clutchs etc etc 5 hours later im thinking,i got 300 plus hours,mabey i ought to check the valve specs.NO problem,right? Big problem,you got to have an act of congress to access them.Got to get that tank out to access them right? unbolted it but couldnt get it out,the plastic body is in the way.Looks like i got to remove the front rack,take all the screws out under the fenders the front rack support,which is most of the front bumper stuff,then the handlebars[it dont look like i can slide the plastic body up by.] Iam starting to think if it aint broke dont fix it.Is there an easier way to access them?[the tank has to go right?] dont look like it can be done from the side access panel area.Is it worth it anyway?
ESCAVADER
Old Mar 4, 2006 | 08:09 PM
crashby's Avatar
i just tried adjusting my valves today, and i couldnt get the front plastic off. so i said screw it and put it back together
Old Mar 5, 2006 | 08:21 PM
ESCAVADER's Avatar
Any body else tried to access them?Are the SPORTSMAN a bit#@#$@ to get at too?
ESCAVADER
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
rawbdiggity
34
Sep 2, 2015 02:16 AM
Hankey Pankey
Aug 17, 2015 05:01 PM
