06 Predator Squeak
Old Mar 6, 2006 | 02:24 PM
DeanH's Avatar
Default 06 Predator Squeak
Has anyone else noticed a VERY annoying squeak coming from right around where the steering column meets the body? If you noticed it, were you able to get rid of it? Every little wiggle to the right or left squeaks. It's the most annoying noise when you're in a rocky area.
Old Mar 6, 2006 | 02:47 PM
Bradracer18's Avatar
I've never noticed it......there is a greasable bushing there though.....have you greased it recently?
Old Mar 6, 2006 | 04:10 PM
DeanH's Avatar
I haven't done that. It's made the noise since I first got it. It sounds like it's the wires rubbing against the front cab. I can't figure out which one(s) is doing it though. I will see if greasing the bushing helps. Thanks for the recommendation!
Old Mar 6, 2006 | 05:11 PM
Could also be the wires you said......there is a brake line that goes down through there......
Old Mar 6, 2006 | 08:18 PM
06LimitedPred's Avatar
It's not really a squeak, more of a creaking, but on either side of the front plastics on the underneath side is a clip where it slips into place on the tank, if one side has come unhooked it can creak, mine did that the other day.
Old Mar 6, 2006 | 08:31 PM
Fixitmatt's Avatar
I was just going to tell you the it may be the clips on the tank.They suck, I took mine off and drilled Holes in the plastic so I could just use a blot.
Old Mar 6, 2006 | 08:32 PM
Fixitmatt's Avatar
oops I ment to write bolt not blot. Dumb F-ck award
Old Mar 6, 2006 | 09:50 PM
Good idea, i might do that with mine if it keeps coming out of the clip.
Old Mar 6, 2006 | 10:54 PM
They shouldn't come out, if properly adjusted, and properly put in. In my personal opinion, I'd just break them off. Mine are broken off, and my plastic fits and rides just fine. There is no slop in it.
Old Mar 7, 2006 | 10:57 AM
DeanH's Avatar
I'll check that out too. Unfortunately, I'm storing it an hour out of town, so I'll have to check it out this weekend. Thanks for all of your input.
That's good stuff!
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Canamaniac!
Sep 4, 2015 06:44 PM
1966F100
Jul 12, 2015 03:08 AM
