4x4 turning on when switch is off 04 700efi.
Old Mar 11, 2006 | 04:20 PM
Madcap's Avatar
Default 4x4 turning on when switch is off 04 700efi.
I am having a problem with the the 4x4. When the switch is off the 4x4 engages. I changed the hub fluid and it still happens. If if put it on jacks the front tires engage 4x4 after the rear tires are spinning for a bit. It slams hard. What would cause this to happen?
Old Mar 11, 2006 | 09:08 PM
hydro's Avatar
This is normal centrifcal force is causing it to shift in.
Old Mar 11, 2006 | 10:58 PM
Sherlock's Avatar
put it in 2wd and back up about 10-20 ft. and try it. My 04 SP 500 does it sometimes too.
Old Mar 12, 2006 | 01:15 PM
Zbart1's Avatar
When is Polaris going to redesign the four wheel drive system!!
It’s been the Achilles heel of their platform for years!
I thought when they came out with the center mounted Hilliard it might help, but I was wrong! The new system is worse then the old system (at least it cut in half the problematic Hilliard’s in the system.)
No four wheel drive going down hill, two wheel EBS on older units and a poorly engineered new four wheel EBS and worse of all a four wheel drive kicking in( with the switch off) at the most inopportune time! And I might add, locking up so hard that it’s causing the front hub to eventually self destruct and worse yet the rider to lose control in some cases. There is already a class action lawsuit about this situation.
I love the ride and handling of these machines …….but I am sick of working on and with this poorly designed system.
Please Polaris …..It’s time for a change……a new V twin engine would be nice,
But getting rid of the Hilliard system is a must!.
Old Mar 14, 2006 | 11:17 AM
springtuckyn's Avatar
Hi Madcap,
I had this happen to my 700. You may want to read this thread... Hilyard
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
cornermike
Jul 8, 2015 11:44 PM
ranvette
Jul 4, 2015 06:13 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
