Muddy Water in Air Box
Old Nov 14, 2000 | 07:51 AM
Loyal's Avatar
Actually it was more on the lip of the carb and on the edge of the airbox. It happeded while driving through some headlight deep water. Bike sputtered and eventually she shut off. There was no water on the piston. I just soaked up the water in the airbox with a tissue and she started.
There was none at the bottom of the airbox. What I'm thinking is that it probably came in thru the bottom of the box, until she flooded and drained out when I got to dry land. ANy other ideas?
Old Nov 14, 2000 | 11:29 PM
Sportsman6x6's Avatar
You might of been one of the lucky few that when it filled the air box with water, you valves shut just right and didnt let any water in.
Old Nov 15, 2000 | 01:24 AM
sixty9cobra's Avatar
Just a thought the hose on the bottom of the air box is supposed to have a red plug thingy in it to keep the water out. This might be your problem.
Old Nov 15, 2000 | 04:56 AM
Bill.Ciliberti's Avatar
You probably sucked in the water thru your air box snorkle tube.You did'nt need to tissue out the water.On the underside of the air box there will be a sediment drain tube,take off the bottom cap on this and all the water would of gone out of the air box.Anytime you exceed the heigth of the airbox snorkle with water levels,you will get water in the airbox,even a quick/hard run thru water could cause a few splashes of water to enter thru the tube and down into the airbox,
Bill
Old Nov 15, 2000 | 07:08 AM
Loyal's Avatar
I'm missing the sediment drain tube and cap at the bottom of the air box. It must be on the garage floor somewhere as I never had the problem prior to removing the box a few weeks back.
Thanks again guys.
Old Nov 15, 2000 | 04:17 PM
truck's Avatar
I have been having problems with my 400 explorer
doing kinda the same thing.I found the seal for the lid on the air box had slightly rolled over.
GOOD LUCK
TRUCK
Customer Service #1
May 15, 2020 08:46 AM
Pgbama11
Jan 16, 2016 08:19 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
