cv joint popped out
1) Take your front hub apart & remove the end of the outer axle from the strut while leaving the strut hanging from the bike.
2) Remove the boot clamp on the outer end of the axle.
3)You can then grab the splined end of the axle & work it till the splines from the inner axle mesh with the splined components that are covered by the boot.
4) Reinstall the boot, clamp & bolt everything together.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
