2001 425 expedition water pump
Old Mar 30, 2006 | 10:37 PM
BigALFX4's Avatar
Default 2001 425 expedition water pump
If the water pump seal goes bad would it cause the crankcase to fill up with coolant?
Old Mar 31, 2006 | 12:18 AM
handycap's Avatar
2 Seals would need to go bad I believe. The water seal and oil seal. Normally when the water seal goes bad the water leaks out of the weep hole and doesn't get into oil.
Might be head gasket.
Old Apr 2, 2006 | 02:47 PM
425Xpedition's Avatar
If the weep hole is stopped up and the mechanical seal is bad the crankcase can fill up with coolant. Had it happen to one of my old Xpeditions.
ltrmc02
Aug 22, 2021 02:34 PM
Customer Service #1
May 15, 2020 08:46 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
chewy78
Sep 8, 2015 10:37 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
