HOT! Light
Old Apr 8, 2006 | 09:08 AM
encorebilly's Avatar
Default HOT! Light
Originally posted by: thedon
would there be anyway to clean the area w/out removing the fan shroud and all the other stuff in the front? that does seem like a lot of work especially if you are talking about the whole front storage area...brushguard and all?
You just have to remove the front storage box to make it easier to get to the fan and shroud not the bumper and brush guard.
I take mine off @ each mud ride and you will be surprised how much mud is in there.I just use a garden hose til it runs thru clean and check it with a light to make sure.
Old Apr 8, 2006 | 06:05 PM
thedon's Avatar
Default HOT! Light
Thanks for the help - That sounds better than I thought. I will try it this weekend.
Old Apr 8, 2006 | 09:04 PM
Backinthesaddleagain's Avatar
Default HOT! Light
You guys just got my curiosity going........my 2004 has a removable plate on either side of the radiator. It goes between the radiator itself and the radiator guard shield. When you remove these (3 phillips head screws) on each side you have excellent access into the front of the radiator between the guard shield and the radiator. You can stick a hose with a spray nozzle right in and douche out the radiator completely and very easily.
Don't the 2005/2006 machines have these access panels on either side of the radiator......if not they should.
Old Apr 9, 2006 | 11:42 PM
thedon's Avatar
Default HOT! Light
You were right.
I was shocked at all the mud on the back of the radiator. I did not have to take off the shroud but I did take everything else apart. With the front jacked up and some creative spraying I was able to get it all. Now that I have done before it should not take too long next time.
Maybe the big mudhole behind my house is not such a good idea.
Old Apr 13, 2006 | 10:26 AM
  #15
rag253's Avatar
Default HOT! Light
I just purchased my 06 sprtmn 500 EFI 3 weeks ago . Ihave noticed the same problem! thanks to these postings I know what to have the dealer check when Itake it back for the break in check-up.
Old Apr 13, 2006 | 07:59 PM
  #16
Default HOT! Light
Anybody?
Old Apr 13, 2006 | 10:14 PM
  #17
thedon's Avatar
Default HOT! Light
If the plate or flap on each side is removable I could not figure it out - and I was looking for a shortcut!
Taking the front box off wasn't too bad though.
Old Apr 13, 2006 | 10:18 PM
  #18
Default HOT! Light
Thanks for the response.
It's a shame those panels are no longer removable.....great easy access into the radiator.
Old Apr 13, 2006 | 11:00 PM
  #19
Nedzilla's Avatar
Default HOT! Light
The panels are removable but they are held on with push pins. Once you get the pins out you geta better view of the front of the radiator. This helps with cleaning while on the trail but in order to clean the back side you have to remove the storage unit.
Old Apr 14, 2006 | 09:55 AM
  #20
Default HOT! Light
Push pins already out of mine because of the jamhard and the brushguard,so have to remove the storage box to do it right.No biggie to take the box off and the fan and shroud out.(15min)
