400 Primary springs
Old Apr 9, 2006 | 11:57 PM
ftwflh's Avatar
Default 400 Primary springs
Either by a Dynoport pipe or clutch the wy it needs
Old Apr 10, 2006 | 12:51 AM
WIscrambler's Avatar
Do you know what RPM that CPI pipe needs to run at? My HPD trail setup pulls close to 6800 rpm's with the HPD red/yellow spring and stock weights.
Old Apr 10, 2006 | 01:50 AM
duneaholic's Avatar
Try a HPD blue primary with the stock weights and a HPD violet secondary spring in the 2-2 position. That pipe revs pretty high. Let us know what you decide and give us a report.
Old Apr 10, 2006 | 10:53 AM
Fastestdad's Avatar
I'm with wiscrambler a red yellow with stock wts, violet secondary spring. I have ran that setup with a cpi on sand too I liked it the best and I tried probably 5 or 6 different setups and I ride sand alot. The dynoport pipe is an absolute dog in sand. IMO Spins and digs down off the line then just dies up top.
Old Apr 10, 2006 | 01:32 PM
  #15
badazz400's Avatar
ok boys speaking from first hand experience, hpd blue with s55 for trail/dune/recreational riding. violet secondary set at 1 to 1
i cant tell you what im runing 4 drag because some of my competition is getting on this site watching every move i make. if you wana know send me a pm. [img]i/expressions/face-icon-small-wink.gif[/img]
ross
Old Apr 10, 2006 | 01:33 PM
  #16
badazz400's Avatar
obtw you need some portwork to really get the most out of that pipe
Old Apr 10, 2006 | 04:53 PM
  #17
Martianman's Avatar
I talked to Mike at CPI and he said the pipe should run 7800-8000rpm.He said he ran the dk.blue primary in his.I guess I'll go through RCR and by what I need,plan on portwork,girdle kit,may set her up on alky!!
Ridgerunner665
Sep 15, 2015 01:20 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
