04 600 clutch carb?
Old Apr 12, 2006 | 07:34 PM
itstillruns's Avatar
Default 04 600 clutch carb?
Got a 600 SP that starts good but the clutch engages at about 1400rpm,however the quad doesnt really start to move until about 1900rpm.This causes the quad to feel like its jerky and unsmooth. how do I fix this? A clutch kit or just shift weights? Thanx
Old Apr 13, 2006 | 11:35 AM
Speedwerx's Avatar
It sounds like your blet deflection and or alignment is off. You probably need to remove a washer or 2 internally from your secondary clutch. The best thing to do would be to get a service manual and clutch alignment tool and do it yourself. Over time we've seen the engines move around a little bit and cause this to happen. Have you replaced your belt lately?
Old Apr 13, 2006 | 01:47 PM
Belt is about a year old,the owner of the 600 doesnt ride it hard but I'll check it and the alignment/deflection. thanks!
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
