Battery Indicator - Please Advise
Old Apr 18, 2006 | 09:10 PM
10ptman's Avatar
Default Battery Indicator - Please Advise
My Battery indicator on my 03 SP500 is reading '126.8' Is this normal or below normal. I am guessing it has something to do with how many volts are left or something. Could someone please advise. Thankyou.
Old Apr 18, 2006 | 09:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that doesnt sound like a voltage reading.it should be between 12.5 to 14.5 volt range. is that a code i wonder?
Old Apr 18, 2006 | 09:57 PM
10ptman's Avatar
ya your right, that wouldn't indicate voltage. I turn the key and thumb thru the different settings (Miles, Trip Odometer, etc) I come to the battery indicator and it reads 126.8, I will need to locate my manual and see what that battery code means. Going on a huge trip down towards chattacoochee this weekend and want to make sure it's in tip top shape so I don't get stuck.
Old Apr 18, 2006 | 10:03 PM
10ptman's Avatar
I bet it has something to do with the percentage of charge remaining in the battery. I just need to find a chart to figure out what is normal, high, low etc.
Old Apr 18, 2006 | 10:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i was just looking thru my manual and i dont see on my 06 800 where it says battery check in the mode settings. are you in the diagnostic mode whil reading that number.
Old Apr 18, 2006 | 10:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the only number codes i ca see is 2# codes like from 21 to 61 the decimal point is what i dont understand like its reading hrs. or the trip.
Old Apr 18, 2006 | 10:30 PM
10ptman's Avatar
I am a true fricken idiot. Sorry for wasting your time. I just went out there your right it's reading hours. I guess I will make sure the battery has enough water and roll with it. I am goin to some deep terrain (miles upon miles away from Civiliztion) this weekend in near Chattacoochee, TN and just would hate if that 03 battery took a shat on me. Sometimes the low indicator light will come on only when I try and start after it sits for a month or so. But just now when I am messing with it, doesn't give me any indication that it's low.
I appreciate everyone's help on this forum. Last weekend i gave the sp500 a complete full srevice from top to bottom and you guys coached me thru some hub issues I was having.
Thanks again,
10ptman
donintennessee
Jan 8, 2021 12:40 PM
Stever6368
Aug 16, 2015 07:34 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
Schneider
Jul 24, 2015 05:05 PM
