PLEASE HELP!!!!
I was helpin a friend drag logs out when a stick got caught poked up through and made a tiny crack in the tranny cover. Is this serious enugh to replace it or should it be ok? and how much would one cost on a 99 polaris xplorer 400 4X4? PLEASE HELP!!!
gee dude sounds like a job for JB Weld. is the tranny leaking huh? if so drain tranny of all oil. the crack must be completely clean. no oil at all. go to your local hardware store or auto parts store and buy JB Weld. JB Weld will seal that crack permanently. forever!
uh... are we sure he's talking about the gearcase? he might mean the plastic transmission cover (which seems more likely to me because he mentioned putting a hole in the cover. Question: how big of a hole, and does your friend ride a lot of water? if the hole's small or your friend doesn't ride much water, it'll be fine. otherwise( i know this sounds kinda chinsy,) but a free fix could be as simple as some duct tape on the inside and outside of the cover to seal it from water. Otherwise, it should be replaced... sorry i can't help w/ a price tho...
If ScramblerXLE is right and it is the plastic cover. Then do as the other's said take it off clean all oil dirt and grime off of it. Then go to any auto part's store and buy A tube of Amazing GOOP. seal it from the inside. Woulden't hurt to put it on the outside either. Let it set for A day and your problem is gone. Great stuff I've used it on many thing's, You'll break it somewere else before it break's there again.[img]i/expressions/face-icon-small-happy.gif[/img]
It is the plastic cover an it is just a tiny crack and we dont ride through water much mainly just draggin wood and other things like that, how long will it last if i dont do anythin at all, i will but fix it but im just curious if i should let it sit until i fix it or will it be ok
A stick did that? We are talking about a stick right? not like a land mine or a titanium reinforced rod or sumthing? Because wtf kinda stick could do that bro. And you need a new case. Iv seen them go for around 200$.. correct me if im wrong
