Crazy brake question!!!
Old Nov 21, 2000 | 01:16 PM
Zorro's Avatar
Put a big disc!!! you will have as little ground clearance as me!! ahaha
Old Nov 21, 2000 | 01:31 PM
EasterEgg's Avatar
Relax! it`s just a difference in opinion.
98 Scrambler 500
00 Trailblazer 250
Old Nov 22, 2000 | 02:02 AM
Dazed's Avatar
Before putting on new pads chamfer all the holes on the roter it will decrease wear on the pads. Make sure you do both sides also. And it dosenrt need to be much.
Old Nov 23, 2000 | 01:07 AM
Xplor's Avatar
chamfer??
Old Nov 24, 2000 | 05:10 PM
  #15
waynaferd's Avatar
chamfer= smoothing the holes' edges so their not so sharp (P.S. do this to a v8 crankshaft to get better oiling) How bout an extra drum brake inside the rim?
Old Nov 25, 2000 | 01:37 PM
  #16
Farmr123's Avatar
I just stumbled across a site that had a place listed that makes a supposed 'bolt on' bigger brake disk kit for some Polaris machines. The company is called FTR and their # is 800-429-9991.
I would see if they have one to fit their machine.
The pads will last longer if you rinse the mud from the rotor holes after mudding. Yes, it is a pain, but I don't mud enough to justify new rotors, etc.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Oct 16, 2019 12:11 PM
Cummins Driver
Sep 11, 2019 01:22 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
