need help starting my 88 trailboss
Old May 2, 2006 | 10:30 PM
cheerio's Avatar
Default need help starting my 88 trailboss
I need help...I cannot get my machine started. It is electric start, but I dont have the key anymore, so I pull start it. Do you still need the battery in proper operation for it to run?
Old May 2, 2006 | 11:41 PM
crazygutz's Avatar
shouldn't, you do need the key turned on and the power switch on for it to start. thats how it is on my 96 tb and probably the same on yours. you probably need the key though.
Old May 3, 2006 | 01:17 AM
lepper's Avatar
as long as the charging system is working it should start dead battery or not. give it some choke (make sure key is on) and pull that thing, also check for fouled plug. good luck! I have an 88 trailboss I totally rebuilt last year.
dave
Old May 3, 2006 | 03:47 AM
scrammersam's Avatar
it needs a complete circuit to run, meaning battery need to be in even if dead, and key needs to be on, you may have to hotwire it if you have lost the key or order a new key,
Old May 22, 2006 | 07:09 PM
cheerio's Avatar
I got it running, but it doesnt want to stay running. I changed the spark plug, and put in some gas cleaner. But it starts and then runs rough, then dies. then I cant get it going again, almost like it flooded.
I think I give up and need to take it to a professional!
Old May 22, 2006 | 07:16 PM
clean the carb
Magistar
Apr 13, 2023 04:39 AM
1000gade
May 27, 2015 12:37 PM
Michael2
May 6, 2001 01:07 PM
RobS
Aug 23, 2000 11:55 AM
sethb
Aug 5, 2000 11:46 AM
