Help . . . Deep Water Runners
Old Nov 21, 2000 | 12:35 PM
Loyal's Avatar
Is it difficult to drain the carb. I have had bad experiences with doing carb work (when I was young and foolish . . 15 . . I did something to the carb on my fathers Trimoto 125 and messed up the engine). Don't ask what . . . cause I don't know . . . only that Dad had to shell out $s to get it fixed. .
That drain tube for the carb . . . is it difficult to find? Which side of the bike would there be easier access and is it on the front, back, side or bottom of the carb?
Old Nov 21, 2000 | 05:32 PM
Sportsman6x6's Avatar
Mine is located on the left side right between the PVT and the engine. look at the bottom of your carb and follow the line that is hanging from it.
Old Nov 21, 2000 | 09:10 PM
RdrD's Avatar
Ok guys thanks for being patient with me......I have the carb vent tube extended up above the handle bars....I have the carb drain screw all the way in....????? Can water get up the drain tube and in the carb when the screw is in?????I believe mudmachine said to crimp the drain....I was just wondering how water would get past the drain screw?????Thanks again....
Old Nov 21, 2000 | 10:50 PM
425Xpedition's Avatar
The water is sucked up the drain tube and goes up through the overflow tube in the bowl of the carb. It is a very common problem. Some bikes come with a oneway check vavle in the drain tube but not ours.
Customer Service #1
May 15, 2020 08:46 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
