Sportsman bigger tires
Old May 6, 2006 | 10:10 PM
RedNeckHillBilly's Avatar
Default Sportsman bigger tires
I have a 2004.5 Sportsman 500 and was wondering if i put a 26x9x12 itp 589 on the front with stock rims if they will rub anything??????????
Old May 6, 2006 | 10:20 PM
20045SP500HO's Avatar
You should be ok ... but remember you have to also put larger tires on the rear to keep the AWD working.
Old May 7, 2006 | 07:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i know i cant put the 9" wide fronts on my 800 because its too tight. you barely have an 1/2" clearance w/ the stock 8" on.
Old May 7, 2006 | 08:41 AM
XShowtimeX's Avatar
I've got ITP MudLite XTR 26x9x12 on the front and 26x11x12 on the rear and have NO problems with clearance, maybe if you put 27x9x12 or 27x9x14 you'll have clearance problems, you'll also loose power with the larger tire and or wheel. I stayed with the stock size as not to loose power. They look great and perform FAR BETTER than the factory tires.
Old May 7, 2006 | 10:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well w/ the stock rims on the 06 800 i dont see how they wouldnt rub w/out buying the aftermarket rims on mine. is your stock rims?
Old May 7, 2006 | 11:46 AM
yes i'm using my stock rims
Old May 7, 2006 | 12:32 PM
Backinthesaddleagain's Avatar
I believe with the stock rims you won't get the clearance. You'll need aftermarket rims with the correct wheel offset. I believe the wheel offset on my ITP Type 7s is 4+3 which works great for the 9" tire.
Old May 14, 2006 | 08:33 PM
hc's Avatar
hc
You may want to check your tie rod ends. They may rub just enough to wear the rubber off the tie rod ends to allow mud inside which will wear the rod ends out real fast.
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
