carb popping
Old Mar 30, 2007 | 11:47 PM
Charlie's Avatar
Default carb popping
On the other hand, all older single cylinder 425s and some 500s can have cam problems. Newer cams have two oil holes on the exhaust lobe and larger supply holes where it comes in from the supply port to the cam.
Old Mar 31, 2007 | 06:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your only getting 80 lbs of compression then it could be because the cam is worn and not letting the valves do their job right. cams were a common thing in some of the bikes but i cant remeber which ones i read about.
Old Mar 31, 2007 | 07:06 AM
sledgehammer650's Avatar
Thanks! I've got a 99 scrambler 500 most post that I've read has been on the SP's. I went to partsland and there cam was over 200 for just a single cam it's not a V-twin. I read somewhere that the SP cam's where around 136. I tried to find a cam from hotcams. Is there anyone who makes a aftermarket cam for a scrambler or will a cam fro the SP HO fit. I'm going to pull the Carb again and take a little more time along with pulling off the shift link to make sure that it goes all the way into gear cause I think I've got two problems going on. Or maybe the cam just makes the engine that weak where it feels like it's starting off in third gear or the brake is applied. It will not even pull up into the back of a truck without a running start.
Old Mar 31, 2007 | 08:55 AM
drlang's Avatar
Sounds like cam to me, the 500 HO cam will work for you also. Make sure you replace the cam follower too. These parts aren't cheap I'll give you that. Doc
Old Apr 1, 2007 | 11:15 AM
  #15
will any years of a 500HO work? witch one will have the most pperformance.
Old Apr 1, 2007 | 11:23 AM
  #16
drlang's Avatar
To my knowledge they are all the same. Again a plugged nickel might be worth more. These cams work in the 425 also.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 19, 2015 10:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
