2004.5 700 EFI FUEL PUMP GONE BAD?
#23
To follow up, the replacement pump works GREAT! Was simple to change and a fraction of the cost of Polaris price. It was great for me that there was useful information in this forum, probably saved me $500.
Don't forget the strainer though... And clean your tank, my old strainer came apart and was all over the gas tank....
Fuel Pump: Airtex E8198 - $80
Strainer: Airtex FS111 - $5
Both available at Autozone (they had to order but only took a day to get there).
I put this on a Polaris 2006 Sportsman 500 EFI and it worked great!
#25
My 05 700 efi camo had the same issue. It would run great till it got too hot them start stuttering till it pretty much died out. It took me a while before I figured it out. One day I took it for a long slow ride then got back home and let it sit and idle til it started acting up. Once it got hot enough and started stuttering then finally died, I poured some fresh cold gas in it and started it up. I t ran great. The problem is the header pipe is heating up the gas too much and causing it to vapor lock, or it just can't pump it. I installed an alluminum heat shield just above the header pipe to keep the heat away from the tank. I have not had a problem since. Next time it acts up try the same thing. Pour some fresh gas in, if it instantly runs great, thats probably the problem.
#26
Good post.Heat can cause problems on fuel pumps. Plus don't forget to check the tank vent as it's routed down the steering post for any kinks that could cause a vapor lock condition along with changing the fuel filter at the front of the atv every two years as recommended.
Elkaholic
Sep 6, 2015 02:44 PM
