premium gas in atv
Old Jul 26, 2006 | 12:50 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Default premium gas in atv
If your machine is stock. Run What you manual says, plain and simple!
Let the what type of gas wars continue. =]
Old Jul 28, 2006 | 06:14 PM
Thor's Avatar
Exactly- I have a 2005 sportsman 500 HO and I have never really thought about it but.....
the owners manual calls for 89 octane which would be mid grade .not the 87 octane regular that we have here in Minnesota. HMMMMMMMMMMMMMMM
Old Jul 28, 2006 | 08:06 PM
Cmott426's Avatar
Originally posted by: spyder6
the only difference between premium gas and regular gas is the octane levels. octane keeps the gasoline from pre-detonating without a spark. also known as dieseling. thats why high-compression motors like corvettes or even the predator require premium gas
Pre-detonating is the fuel igniting before the spark. When the spark does ignites the fuel it "Slams" the other flame front and makes a "Ping" "knock" sound, that’s why its called pinging or knocking. Dieseling is the fuel igniting without a spark and keeps the engine running with out a spark. Like when the motor keeps running after you turn the key off. Higher octane prevents the fuel from igniting without spark.
Old Jul 28, 2006 | 08:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not to mention when your timing is advanced to far you get the same reaction not shuting off. good example of the dieseling is how a trator trail engine works w/out spark. pure compression to cause the ignition of the fuel.
Old Jul 29, 2006 | 02:59 AM
  #15
gt350tsc's Avatar
my warrior online manual say 86 or higher. my dealer runs 93 gas in the atvs they have
Old Jul 30, 2006 | 02:24 AM
  #16
MnFriesen's Avatar
If your engine has a high compression ratio, then use the 91 octane, if not, use 87. The perfromance could actually be hinderd by using a higher grade of gas. Just do a search for it on the forums and the information is there...
Old Jul 30, 2006 | 10:36 AM
  #17
04TLDPRED's Avatar
predators don't require premium from the factory.
Old Jul 30, 2006 | 02:54 PM
  #18
imconstipated's Avatar
you dont need to but I think it helps when I am going on longer rides
Old Sep 20, 2006 | 09:56 PM
  #19
hotdog's Avatar
Anyone know the compression ratio in a 2001 SP 500HO ?..I have always used premium gas..A friend of mine who has been driving Honda 350 a long time.said that's what he used..it ran better
Old Sep 20, 2006 | 09:59 PM
  #20
06LimitedPred's Avatar
You sir are correct
