premium gas in atv
Old Sep 20, 2006 | 10:37 PM
  #21
squeege's Avatar
Default premium gas in atv
I ran 91 my last ride and noticed my quad ran better.....If I remember right the airbox lid states 89 or 91 as the proper octane
Old Sep 21, 2006 | 01:46 AM
  #22
sheepdogMSP8117's Avatar
I can't tell the difference between 89 and 91 or 93 in mine, so I just use 89.
Old Sep 21, 2006 | 01:38 PM
  #23
Cormacs's Avatar
The manual for my 2006 sportsman 500 EFI says minimum octane of 87, it doesn't say it can't be exceeded. But if these engines are suseptable to the same problems as car engines, running high test will carbon up the engine faster. No real problem just run combustion chamber cleaner through it more often.
Old Sep 21, 2006 | 02:49 PM
  #24
paintballbanshee's Avatar
can someone tell me that premium gas burns faster than regular??? what burns faster and why i never understood it!
Old Sep 21, 2006 | 06:51 PM
  #25
Zbart1's Avatar
IT BURNS SLOWER
Here is an old post of mine...........
Iwrote this for a snowmobile forum and have posted here:
Well I will try to give you a short version of this :
premium gas was and is designed to protect your engine against detonation. and it does this because of the chemical makeup of long branch tightly bonded molecules. Where regular gas has a molecular structure that has less of a bond.
The chemical composition of the fuel determines how fast the fuel will burn and if it will work well with high compression or temperatures.
fuels with weak molecular structures [regular] will break down more quickly or burn spontaneously [detonation] at lower temperatures.
Fuels with tight molecular structures [ premium] burn more slowly and take more pressure and heat to fully break down and burn.
therefore putting premium fuel in a engine not designed for high octane fuel [I e not having high compression or spark advance ] will not be able to break down the chemical bonds. And will not completely burn the fuel charge therefore produce less power.
So you see next time your at the pump buying that 115 octane racing fuel for your sled that costs five dollars a gallon. you may want to reconsider. And by the way no fuel can be over 100 octane ! It's a percentage
Run the type of fuel your manufacturer recommends !!!!!
Old Sep 22, 2006 | 03:51 AM
  #26
jimmypsp700's Avatar
If your machine is stock run what the owners manual calls for or you could be reducing performance.
If its modded and higher compression use Premium.
Also if its old and worn higher octain may help.
I run regualar in my sp700 and premium /super in my trail modded and ported scr400 (recommended by HPD).
Jim
Fuel For Thought
By Rich Rohrich
Part 1 - The Basics
http://www.eric-gorr.com/tech/tech_main.html
Old Sep 22, 2006 | 01:56 PM
  #27
Oloff700efi's Avatar
Polaris owners manul says 87 octane for fuel.
"IF" you live in state that requires oxygenated fuel (minnesota 10% ethano ) then you run 89 octane.
Anything higher than 87 is a waste of money unless you have increased the compression of the motor.
Polaris Side by Sides
Sep 15, 2015 03:33 AM
Shawn_z400
Jul 1, 2015 03:37 PM
delmer
Apr 6, 2002 10:01 AM
SWAC1
Nov 19, 2000 10:53 PM
Loyal
Oct 24, 1999 09:06 PM
