oil filters.......brands
#15
daddycool..I personally service about 15-20 Polaris Atv's..I use nothing but Napa 1358 oil filters for 400-450--500 and Mobil One 0-40 oil...For the twins (600-700-800 )I use Napa 1357..We have Atv's with over 8000 miles and as of yet have not had an engine failure..Sure hope his helps...Ride Hard- Ride Safe
#16
Twins...
Wix filters:
Part Number: 51357 (600/700/800 twins) NAPA Gold 1357, AC Delco PF2112, Amsoil P502057
UPC Number: 765809513570
Principal Application: Ford Probe (89-97), Mazda Cars & Trucks (83-96), Kia Sportage (95-02)
Specs.
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Set-PSI: 8
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
AC 2057 and Pure One PL14610 will work as well.
Wix filters:
Specs.
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Gasket Diameters
#17
single cyl sportsmans...
Wix filters:
Part Number: 51356 (closest alternative to 51357) AC Delco PF2057, PF2112, Purolator PL14610, Mobil 1 M1-110, Fram PH7317
UPC Number: 765809513563
Acura (02-06), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-06), Infiniti/Nissan (96-06), Mazda (71-00),
Mercury Villager (99-00), Mitsubishi (90-06), Saturn (04-06), Outboard Marine Engines, Various HD Equip.
Specs.
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
By-Pass Valve Set-PSI: 8-11
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Gasket Diameters
Wix filters:
Specs.
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Gasket Diameters
#19
