Tire rubbing tie rod end
Old Aug 7, 2006 | 10:46 PM
evinrude86's Avatar
Default Tire rubbing tie rod end
My tie rod is rubbing my tire on the right side. Magnum 425 4x4. I've tried everything I can to get clearance but to no avail. Any ideas of what's causing it?
thanks
Old Aug 8, 2006 | 12:03 AM
thedoc's Avatar
seems impossible unless tires/wheels are too wide
Old Aug 8, 2006 | 11:15 AM
2001Bansheeboy's Avatar
If it's only on one side, I'd say something is bent
Old Aug 8, 2006 | 11:24 AM
upnort's Avatar
Is this with stock tires & rims? Some have put aftermarket on (including me) and had this problem.
Old Aug 8, 2006 | 11:41 AM
Mudrooster's Avatar
Try using some washers on the studs behind the rim as spacers to give you some clearance.Try like 2 or 3 on each stud.My do the trick. Mudrooster
Old Aug 8, 2006 | 10:58 PM
thedoc's Avatar
but seems hard for it to be bent as the tie rod attaches to a solid arm which is part of the die cast hub assembly
seems it would actually break off before bending, and then he would have no steering at all, so must be oversize wheels and yeah spacers would help [but might overstress the wheel bolts]
besides with mine there is only about half inch at most extra thread to play with
Old Aug 10, 2006 | 05:52 PM
evinrude86's Avatar
Just a tad oversized superswamper tires, but only the right side rub. I previously replaced all the tie rod ends both inside and out, checked to toe-out and adjusted.
Solution was to put longer wheel studs and 5 washers between the wheel and tire on the right side. She's good as new and dont' rub me wrong no more.... also can't tell any difference in the ride or handling.... cheap fix.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
