NO Electrical Power
Old Aug 10, 2006 | 12:58 AM
crashem's Avatar
Default NO Electrical Power
My Polaris 2000 400 Xplorer has no electrical power - lights,spedo,starter,awd,fan. I have tested the battery and it is good. Anybody had this problem before?
Old Aug 10, 2006 | 01:57 AM
bjrjr16's Avatar
hey, it could be your positive feed wire coming from the batt. or i think theres a fuse or breaker somewhere that kicks all that off. My wheeler had done a similar problem. it had no lights, 4wd, electric start, ect all when not started butonce it was started i only had lights, sometimes it would shut off the wheeler on its own, well yea it was the positive wire came lose from the starter and the ground wire completely came off and would be setting on the frame and eventually would work its way over to the pos lose wire and contact and shutdown the wheeler. idk how all thishappened but once i re located the ground wire and reinstalled the pos wire everything worked great and no more shutting down. i rode that sucker for 5 months before i realized thats what was wrong. It was middle of winter with no snow when i got around to looking at it, then i got her out and rode it after i fixed it. then the wires came loose again and had problems over then just relocated the ground wire. Hope this helps, Brian
Old Aug 10, 2006 | 07:02 AM
thedoc's Avatar
beside the battery is a black box about 2 inch square and they call it a solenoid cept I think it is more like an auto reset circuit breaker, effectively doing the job of "fuses" as you have on a car
in fact the parts manual names the wires in and out as "solenoid" but the solenoid itself dont get a mention
make sure the terminal IN and OUT of this are sandpapered back to metal or bike no go
because I live and drive in super corrosion area I need to do this every 6 months [as I found last week when my starter switch just said "click"]
there is also a "control" terminal on upper left and it too needs to be making proper contact
Old Aug 10, 2006 | 03:52 PM
XxScrammy500xX's Avatar
heyy this happend on my dad magnum 500 and all it was was the ground wire wasnt grounded and the whole thing shut down just hooked it back up and wwas good to go
Old Nov 2, 2006 | 10:30 PM
rubberknob's Avatar
what was your final out come??? I have the same problem with my 05 ATP 500HO, I think it maybe my ECM. does your atv start with the recoil??
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
akbrewcrew
Aug 9, 2015 10:54 PM
Derek Allen
Jul 22, 2015 09:25 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
Unzzy66
Jul 11, 2015 10:01 PM
