New piston HELP
Old Aug 10, 2006 | 03:21 PM
XxScrammy500xX's Avatar
Default New piston HELP
hi everyone i recently spoke to my shop and they said my scrammy 500 needs a new piston and all gaskets and seals and rings and a new petcock and i got an estimate of 1100.00 can anyone tell me if im getting ripped off thanks
Old Aug 10, 2006 | 06:48 PM
Bradracer18's Avatar
For parts I'd say you've got .....
$120 for piston
$50 for gaskets
....don't know how much for seals...don't think there are any....
don't know about the petcock...but I bet its cheap.
See how much labor is.......
Old Aug 11, 2006 | 04:51 PM
chevyboy400's Avatar
When my scrammy 400 blew its engine, i ended up spending around $800, but i also cracked the crankcase, bent the rod, and scored my cylinder. I disassembled it and took it to a local shop and got a wiseco for like $110, labor was like $80 an hour all he shop did was true my crank up and put the rod on because he told me it was a tedious task. gaskets were $54 i thought, and i dont remember putting seals in it BUT THAT DOESNT MEAN THERE ARENT ANY. the cases were $330, if you have a torque wrench that will go up to 20 then you could probably do it yourself if you are mechanically inclined. Check my pics if they help any, but if you do it yourself you will save some $$$ but if you have no clue what to do do not attempt. oh and the brass crank nut needs a special socket and it is left hand thread shop will probably have to take that off too i messed mine up trying to take it off myself.
Old Aug 11, 2006 | 04:53 PM
[quote]
since when are polaris parts cheap?
Old Aug 11, 2006 | 05:09 PM
true.....but I was kinda being relevant.....like as in maybe $20 compared to his $1100 bill.
Old Aug 11, 2006 | 11:12 PM
cornbread2's Avatar
It would cost you less than half that in my shop in Ky.
Old Aug 11, 2006 | 11:14 PM
cornbread2's Avatar
[quote]
Originally posted by: chevyboy400
[i]
They have always been cheap compared to Honda parts.
Old Aug 12, 2006 | 05:15 PM
motoman67's Avatar
sounds high to me takes approx 5 hours labor and $175 or so in parts to do a topend rebuild. the only seals in the topend should be valve seals.
Old Aug 13, 2006 | 03:19 PM
thanks for all your input guys i went down to the shop and they re quoted me at 700 minus the 33.00 petcock and 109.00 compleate gasket kit and they ended up billing me for 5 hours labor and 90$ an hour.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
