sportsman AWD problem
Old Aug 12, 2006 | 03:11 PM
js380's Avatar
Default sportsman AWD problem
i have a 1999 335 sportsman and when i put tha atv in AWD it works fine in reverse,
but the AWD will not work at all in forward .i just installed a new battery and i still have the
same problem.if anyone can help me solve this problem thanks in advance.
Old Aug 13, 2006 | 01:31 AM
xler8ion's Avatar
Since the awd is working in reverse it fairly rules out a mechanical problem. It sound like a possible electrical propblem from the switch to the hilliard. You can diagnose this by separating the connector going from the switch to the hilliard, pluging in a voltmeter to the connector on the switch side, turning the key or engine on and throwing the awd switch. You should have @ 12v at the connector.
Old Aug 14, 2006 | 12:58 AM
js380's Avatar
also note: that the AWD light will come on when in reverse and i am pressing the overide button
and the awd works fine.but it will not come on at all in forward gears low or high,i even pressed the overide buton in forward and still no AWD light and no AWD.
also note: the neutral light will not come on at all either,i checked the bulb and it is fine.
Old Aug 14, 2006 | 01:07 AM
xler8ion's Avatar
That even makes it more imperative that you check the connector as I explained. If there is no voltage at the connector follow the lead toward the switch and see where the fault is. There must be a link between the gear selector and the switch that is causing the problem. You may be able to download a service manual that has the wiring diagram if you get stumped due to the wires running into the harness.
Old Aug 14, 2006 | 04:33 PM
js380's Avatar
does any one know where i can download a service manual for my
1999 335 sportsman?
Old Aug 14, 2006 | 05:47 PM
bugmanjr3351's Avatar
If you have the letters at the bottom of your guage that tells you which gear you in ( H, L, N , R ) make sure there working. If not that will keep AWD from operating..
Old Aug 14, 2006 | 06:10 PM
js380's Avatar
my sportsman does not have those lights in the speedometer it has the lights seperate
for OIL TEMP - NEUTRAL - REVERSE. but the neutral light dont work at all.
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
