help with intermitten starting problem
Old Feb 2, 2007 | 07:35 AM
hdnvn's Avatar
Default help with intermitten starting problem
Hey there..did you ever get this problem solved and if so what was the solution? I have the exact same problem, vent line dripping, etc. I hooked a booster up to the quad and it starts immediately. I'm not sure if its the battery, coil, spark plug wire...? Thanks for any feedback
Old Feb 2, 2007 | 09:53 AM
TORK's Avatar
A possibility that has not been mentioned, are the crankshaft seals leaking. On two stroke seals must hold vacumn and pressure. If they are leaking when bike is brought up to temp it will make it hard to start. When cooled down they are sealing. Also when jump starting you are cranking faster and possibly overcoming part of the leaking problem. TORK.
Old Feb 2, 2007 | 11:39 AM
GarryESE's Avatar
Another possible cause not mentioned is the fuel filter.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
