K&N Clamp on
Old Aug 20, 2006 | 12:00 PM
spyder6's Avatar
Default K&N Clamp on
Originally posted by: madmatt1971
Spider,
Switch filters and see who much longer your oil remains clear. The dust helps contiminate the oil as part of the blow buy. Also since you have a cummings I'd recomend that up upgrade to the Proguard 7 filter element. I've got a PSD and I'd run away from the K&N as it dated by todays stds. Most high quality paper filters are infact synthetic filter media and it is very efficient and is very free flowing. IMO Race motors are a different can of worms as they are torn down more fequently than the daily driver. I've seen picture of dusted trubos on the PSDs the wear is shocking because the trubine fins are sanded off the spindel from the dust let thorugh by the k&n and the high revs they make. Just my .02
the filter on the cummins is the Progaurd7. as far as a contaminated oil, sport quads need new oil and an oil change even before the oil turns black, so it dosnt really make a difference out of oil longevity.
i agree, K&N's for road applications are junk, but unless im going to be going through the desert with a convoy going through a storm of dust, im not going back to paper. i wub my AFE
Old Aug 20, 2006 | 12:03 PM
spyder6's Avatar
Originally posted by: sheepdogMSP8117
One of the things that I like the most about K&N is the ease of cleaning and re-oiling. Just spray the filter with cleaner, let it soak for 10 minutes and rinse. Let it air-dry and then spray oil onto it. No need to wear gloves, no need to get oil all over the place, and the filter will last forever. Even if you have to clean it more often, big deal, since it's so easy to clean.
the plus about a foam filter though if you get hydrolocked in the middle of no were and can dry your motor out, without oil a K&N Is worthless, a foam filter though, you can wring out and put back on and it will still function. if you try wringing out your K&N you'll just F it up bad
Old Aug 21, 2006 | 02:00 AM
sheepdogMSP8117's Avatar
Good point Spyder.
STLyamwar
Jul 25, 2020 04:44 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
randymack
Aug 24, 2015 05:47 AM
toonces
Aug 13, 2015 01:48 PM
