scrambler plug wire
Old Aug 16, 2006 | 10:18 PM
79Oakley's Avatar
Default scrambler plug wire
my friends 99 scrambler plug wire keeps falling off. is it hard to put a new end on it? its very loose. also when you first try and put it in reverse it wants to die unless you hold the override in. any thoughts
Old Aug 16, 2006 | 10:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it could be that its not getting good contact so its misfiring in the cap it self. im not sure w/out looking at it but most caps are just kinda or srewed on and off so you could buy an ngk plug cap and srew it back on to the plug wire. i also would check to see if the wire is in good condtion and not pulling out of coil.
Old Aug 17, 2006 | 04:44 AM
79Oakley's Avatar
its the wire end i can reach in and hold it down and it will fire back up after it dies.
Old Aug 17, 2006 | 08:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
should be an easy fix then. try unsrewing it and see if turns. make sure not to let the wire turn just the end cap.
Old Aug 17, 2006 | 11:04 AM
conig's Avatar
i do alot of plug checks and I can tell you the caps just don;t last. I seem to replace one a year there only like 1.95 so no big deal, this and the bushing for the pull start I have made part of my maintenance.
HPD has a cap they list to only go with there upgraded ignition but I have had another forum member advise me it does work with the stock ignition. It has a clip to hold the plug on.
http://www.hpd-inc.com/400model.htm
Old Aug 18, 2006 | 08:12 PM
scramblered's Avatar
i highly suggest you the hpd wire that came with their ignition upgrade kit,,you can buy it seperatly as well,really worth the money,it is kinda like a msd type wire without the sign on it,,i do alot of test too and that one fit tight and very well on ngk spark plug,,just spray a little of electrical cleaner once a while through it and will even fix better then...
Old Aug 18, 2006 | 11:43 PM
79Oakley's Avatar
i picked a nkg replacement cap up today for 5 bucks. it was easier to instal than i thought it would be. thanks for the help.
Old Aug 19, 2006 | 12:41 AM
scrammersam's Avatar
the only way i know of to get around the reverse stalling is to do an override bypass. i did mine by pulling a purple wire comeing from the shifter.
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Chocobamofo
Jul 10, 2015 07:46 PM
D-Hagz
Jul 4, 2015 02:19 AM
