99 scrambler 400
Old Aug 17, 2006 | 10:24 PM
79Oakley's Avatar
Default 99 scrambler 400
what does the oil and gas mix at if you are doing it yourself. is it 40,32,or a 50 to 1 ration. also how do you replace the spark plug cap. mine is worn out and vibrates off at speed.
Old Aug 18, 2006 | 07:59 PM
scramblered's Avatar
mix it at 40:1 or 42:1 for the fine tuner,,i've tried many mix ratio,the latest was at 35:1 and oil was spitting out the reed cage so,alot too rich,50:1 is fine but tend to wear out the piston too fast than you would like to be,,
in the park plug cap,i would change the whole wire tough,,,you just have to screw them in til a normal tension is
obtained...
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
