O.K...common way to change oil!!!!!
Old Aug 19, 2006 | 11:36 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default O.K...common way to change oil!!!!!
Well lets here of the different ways you guys(girls) change your oil......Do you really need to go through all the steps in the manual???????come on...can't you drain the oil from the drain plug......remove the filter......add new oil(0W40)syn. WHAT IS WRONG WITH THAT.......Please tell me otherwise....caper...................THANKS.....
Old Aug 19, 2006 | 11:56 PM
spyder6's Avatar
well, they'res the extra oil bubbleing around in the crank case, probebly ends up being a 1/3 of a quart. priming your oil pump is for when there isnt any oil left in the lines
Old Aug 20, 2006 | 12:03 AM
Correct me if I am wrong.... but there should be oil in the lines if you only drain the oil res. tank. caper
Old Aug 20, 2006 | 12:16 AM
motoman67's Avatar
yes there should be oil in the lines if you only drain the tank but polaris wants you to prime the pump every time as a precaution
Old Aug 20, 2006 | 12:28 AM
Why have the filter then......If it's only about 1/3 of oil left......the filter should pick up any deposits left in that small amount.....besides it's synthetic oil....... also.......when you do your car's oil do you let it drain for about two hours??????NO...so there is still some oil left there also...caper....
Old Aug 20, 2006 | 12:34 AM
I mean the filter is there for the oil being left in the lines......RIGHT caper....
Old Aug 20, 2006 | 01:54 AM
sheepdogMSP8117's Avatar
Why do a half-arsed job?
I just changed the oil on my '06 500 HO three days ago. The oil tank drain plug and the filter are definitely the easy parts. The crankcase drain plug isn't in the best place but is fairly easily doable. The oil tank screen filter is another story. First you have to disconnect the rubber tubingf from the line, which was a fair PITA. Once that is off, it takes a 22mm wrench to remove and install the fitting. I used two wraps of teflon tape when I put it back on and it took three turns to line things up. Two quarts of oil put the level about 3/4 of the way into the normal range on the dipstick.
The whole process is easier if you remove the floorboards from each side.
Old Aug 20, 2006 | 02:07 AM
ToSlow's Avatar
Does Polaris call for priming the pump on the newer models? the reason I ask is because in the manual for the 99-00 500 Scrambler they never say anything about it in the oil& filter change
Old Aug 20, 2006 | 02:15 AM
Speaking for my '06 500 HO, it says to prime the pump whenever the line between the bottom of the tank and the engine has been disconnected.
Old Aug 22, 2006 | 11:30 PM
SCRAMMYTODD's Avatar
ALWAYS PRIME THE OIL!!!!!! My boss on his Ranger drained the res BUT not the crankcase and still blew the motor. I always drain the res and crankcase but not always the screen. I've heard of people cracking the res trying to get the screen out but mine was good. And if you went to get an oil change in your $35,000 truck would you like it if they only changed some of the oil and sometimes the filter??????
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
