Brake Fluid Leak
Old Aug 22, 2006 | 08:45 AM
Polaris5's Avatar
Default Brake Fluid Leak
I have a 2005 Sportsman 500. Brake fluid "was" leaking from the brake resevoir cap. I removed the cap, applied a small amount of RTV sealant, and reinstalled the cap. The leak has stopped.
Unfortunately, it appears a have another leak somewhere else. Brake fluid is accumulating on the bottom of the resevoir. I checked the steel braided brake line connection to the resevoir, and it is dry.
-Any suggestions as to where else it may be leaking, and how to fix it?
-Are these brake fluid resevoirs notorious for cracking?
-What about the plunger that is moved in and out when the brake lever is applied (are these notorious for leaking)?
-Should I just buy a completely new resevoir, and throw away the leaking one?
I appreciate your comments and suggestions on how to fix this.
Thank you
Old Aug 22, 2006 | 10:39 AM
NBsportsman's Avatar
If the cap screws are not real tight it will leak from the cap run down under and drip on the floorboard...
MaasaiMomma
Mar 25, 2021 11:24 AM
Shainasmash
May 8, 2017 06:38 PM
toonces
Aug 25, 2015 06:09 AM
Stirling
Aug 9, 2015 01:49 PM
Sandman2.0
Jul 21, 2015 09:03 AM
