2002 Scrambler 500 4x4-NEED HELP!!
Old Aug 23, 2006 | 04:55 PM
xbox's Avatar
Default 2002 Scrambler 500 4x4-NEED HELP!!
I bought a slip on pipe, jet kit and clutch kit and now it keeps dying and acts like it is free wheeling, not downshifting when i let off the gas. I think I need to adjust the idle to keep it from dying but I don't know about the not downshifting. Can somebody help. Thanks
Old Aug 23, 2006 | 06:08 PM
ftwflh's Avatar
Did you preload the secondary clutch spring when you changed springs?
And be sure you dont have any intake leaks on the carb .
Old Aug 23, 2006 | 06:21 PM
scramblerXrated's Avatar
what components were in your clutch kit?? did you install it? or have someone do it for you?
X
Old Aug 23, 2006 | 06:29 PM
xbox's Avatar
I had someone do it for me, I'm going to take it back to them tomorrow and that is why I was needing help, so I could tell them what to look for or do. I know it came with weights, helix and springs, I'm not sure which springs, I will look and see if it tells on the paperwork. It is an epi kit, I don't know if they pre loaded it or not, but I called epi and they said that it sounded like the secondary spring needed to be wound, which i'm guessing is the same thing as preloading.
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
