Need help with trailblazer , anyone from maine ?
i just got a 9? trailblazer from my little brother who broke the swingarm in half for a ps2 and a little bit of cash. now ive already had one but it was over a year ago. so pretty much i need a new swingarm , or im just gunna weld it. also i need help on removing the oil injection system , i wanna run premixed gas. any more info would be great thanks guys
Originally posted by: stendori
depending how bad its broke and how much punishment your going to do you could weld it. see if you can buy or get a used one. just wondering, why do you want to screw w/ premix gas and take out the oil pump?
does anybody know how to get the swingarm off ? it looks like ive gutta take the rear brakes off and the clutch cover to get to it ? also i know somebody has got rid of there oil injection and if so could you help me with it. if anyone has a swingarm i could buy that would be swell , i also need a set of rear rims and front tires , thanks guys
anybodykilla, i've never heard of an injection stop working and never had any problem w/ ours but i suppose theirs always a first time. here is a number on ebay for a swing arm : 170019876994 just type it in on serch and you'll see it. its for 47.00 i think. also i saw a set of rims as well.
also the pump is gear driven and activated by the throttle via w/ a cable. you could unhook the cable and no oil would flow. not sure what would happen to the gear w/out the oil pump letting oil out. i'm guessing mind you but i would think you would have to take out the gear. maybe someone esle can help w/ that. good luck.
i have a 2000 tb. 1st i would not get rid of the oil injector. it would be a pain carrying premix oil and then the oil to mix when you can just fill the tank and forget it for a month. second just buy a new or good used swing arm while it is out i would go ahead and put new bearings in the axle. if he jumped it that hard i would say they are messed up. i am going through this with a friends axle on a scrambler and its not fun.
maybe i should buy it,resell to you for a small profit margine. lol. just so you know i looked up the price for a new one on ronnies and they are $290.00. i put 95" as year as i dont know your yr. is there any way to weld and support it w/ more metal braces. i would have to see a picture and i could tell you better. try to find a local welder down there in rockland and ask them if it would last if they weldered it. as far the injection goes its (to me) more of a pain in the a.. to unhook then to run it w/ it in. just make sure its working and adjusted right and you shouldnt have any problems.
