Why 0W50 oil in Hawkeye?
Why does Polaris spec 0W50 oil in the Hawkeye? I run Mobil1 0w40 in my sportsman, but the Hawkeye calls for 0W50. I can't seem to find this oil anywhere except at the dealer.
Would 0W40 hurt anything? What would the possible problems caused from running 0W40? I think the Hawkeye has a "wet clutch" that runs in the engine oil. The wet clutch grabs the shaft attached to the drive clutch in the PVT and I assume the belt is always tight as it has no lag at all, like my Sportsman does.
Originally posted by: trailblazzers
it should have to do with being only air cooled i believe.
Erik trailblazzers@shaw.ca
