Polaris "do not grease" Fittings?
Only grease fittings Polaris owner's manual wants you to grease are the ball joints and the yoke on the drive shaft. What about the fittings on the a-arms? I have heard of fittings like that on machinery occasionally only used to purge contaminants. Should they be greased or not??? Manual indicates that the other fittings are greased for life at the factory?
John Boy
07-13-2015 11:16 AM
2004, 2006, 330, 400, adding, atv, driveshaft, fittings, fourwheeler, grease, polaris, polarisgrease, rear, scrambler, trailblazer, zerks, zirk
