2003 Sportsman 700 (good deal)
Old Sep 8, 2006 | 08:30 AM
SAshton's Avatar
Default 2003 Sportsman 700 (good deal)
03 Very good condition except for rt footwell outer edge torn. no rust anywhere.no dirt(clean as can be) plastics have minor scratches. has 611 miles and 147 hours. (Is that ALOT) runs fine. comes with motorcycle jack, extra oils, new oem rims to mount bigger tires(stk rims are perfect) tires are 70% and original. has winch and 4 ft polaris ez mount plow. is 5,000 a good deal? Is mileage & bhours ok? I had it runnung for awhile so it runs good. Can u check the temp on the? The Battery light came on for a second then shut off when i revved engine. I had the lights on and the idle was real low. I figured its no big deal. What d ya think guys?
Old Sep 8, 2006 | 10:12 AM
zorro700's Avatar
I'd say you can do a lot better. I just checked on traderonline and found a couple that I would definately pick over that one. ex.
2004 POLARIS, 700 EFI SPORTSMAN, front brush gaurd, rear bumper, only 280 hrs, very clean!, blk & silver, only $4799 ; call TAHOE MOTOR SPORTS 651-322-7533 for more info
Old Sep 8, 2006 | 12:46 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
That is not a lot of miles, anything less then 1000 is good to me. Does it come with a warantee? I would be a little worried about that battery light though. Check to see if it has enough water in there. YOu can't really check the temp without installing a temp gauge. I put one on my ATV and it was very easy, just head to NAPA and pick up a cheap one. If you are just wondering if the temp light works it should come on when you turn the key then go off when it starts. Good luck.
Old Sep 8, 2006 | 07:19 PM
trooperK's Avatar
$5000 is a little steep. If you could get him down to 4500 it would be an OK deal. 611 miles is low for an 03. I bought an 04 700 sportsman Mossy Oak with winch,rack extentions, new goodyear tires in June for 4750 but it had 200 hours and 2000 miles. It was absolutely perfect condition though guy who traded it in was 83 years old. I commend any 83 yr. old guy that can put 2000 miles on a 4 wheeler in 2 years [img]i/expressions/face-icon-small-smile.gif[/img] Great machine I love it.
Trooper
JackTheKing
Jun 14, 2015 03:04 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
