Curious
Old Sep 19, 2006 | 10:59 PM
Cormacs's Avatar
Default Curious
If the Sportsman 500 EFI has an electric fuel pump what is the point of the recoil? If the battery is dead what will power the fuel pump to get that inital pressure to get the engine running. I'm just curious more then anything.
Old Sep 20, 2006 | 12:17 AM
HYPEracing's Avatar
Default Curious
probably just there incase the starter takes a dump
Old Sep 20, 2006 | 01:04 AM
Instigater's Avatar
Default Curious
There needs to be some voltage for the electronics to work. Someone on here one time said, something like 9.6 vdc. That will not crank an engine, but it will power the electronic stuff so you can pull it.
Old Sep 20, 2006 | 09:01 AM
Cormacs's Avatar
Default Curious
So really, If you have a stone dead battery it isn't starting without a boost.
Old Sep 20, 2006 | 09:10 AM
poweraddict's Avatar
Default Curious
the recoil WILL start your machine should the battery die. The battery is mainly there to turn the starter. Once the bike is running, everything runs off the power of the alternator (stater).
Old Sep 20, 2006 | 09:13 AM
HYPEracing's Avatar
Default Curious
how so? if its EFI, then where does it get the power from to run the computer, and injectors to give it fuel to start?
Old Sep 20, 2006 | 10:19 AM
Instigater's Avatar
Default Curious
I THINK spyder6 is the one that mentioned 9 point something volts. He'll probably chime in here shortly and either correct me or give you the info he has. You could PM him if you want. He is good to deal with!
flyin-lowe
Dec 1, 2017 03:18 AM
bigred20653
Oct 2, 2015 10:05 AM
cboler9
Sep 24, 2015 08:35 PM
Albertaboyy
Sep 9, 2015 09:51 AM
polarisrider1203
Aug 29, 2015 07:52 PM
