head cut on 400 two-stroke
Mrtwostroke, you can go out as far as 75% of bore width as long as it's shaped correctly. I have an old sport jug still running today with that figure. 70-72% is good for excellent reliability. You need to drop the intake ports 5mm and work the floor from the reedcage area into the cylinder. Dont let it be a bottleneck. As for the head, ideally you want to end up with about .050 squish clearance, and about a 12mm wide band for good torque. Now to get an absolute compression figure you will have to CC the head assembled on the engine and do the math from there. Boring tedious work, but it will be worth it in the end.
jrooker6
04-23-2016 07:36 PM
1ArmBandit
55
10-14-2015 09:03 PM
Quadzilla Heritage
09-25-2015 01:39 PM
09-23-2015 06:23 AM
