scrambler stearing problum!!!
Old Sep 27, 2006 | 01:01 PM
biddog's Avatar
Default scrambler stearing problum!!!
i have a scrambler 500 H.O 4X4 and i am haveing problums with it the right side is kicking in to 4 wheel drive wen i try to spin 1 of the wheels will kick in and pull hard!!! never had any problums til now do that all do that??? or what
Old Sep 27, 2006 | 02:30 PM
scramblerXrated's Avatar
change your hub fluids.... that will usually take care of that problem
X
Old Sep 27, 2006 | 05:11 PM
biddog's Avatar
i did that thats the first thing i did
Old Sep 27, 2006 | 06:06 PM
ftwflh's Avatar
What yr of Scrambler is it?
You may need to take the hub apart to clean the parts and check the spring around the clutch.If the spring is worn it will let it kick in on its own.
Old Apr 23, 2007 | 06:58 PM
biddog's Avatar
Well haven?t posted for long time but I did it the spring was vary warn so I fixed it now working like new
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
