X2 Suspension
Old Oct 5, 2006 | 04:37 PM
POL700's Avatar
Default X2 Suspension
Can anyone here that has or has riden the X2 comment on the ride when only 1-up? Is it stiff or uncomfortable, does it bounce over bumps instead of sucking them up. Any comments good or bad!
Old Oct 10, 2006 | 10:44 AM
It is stiffer than my friends 2002, and 2001 Sportsmans. Not as stiff as my sons 2005 ATP 500. I weigh 340 and find the ride to be very good with or without a passenger. It can seem a little stiff at times in tight whoops, but is fantastic in technical stuff like tight rocky trails.
Old Oct 10, 2006 | 09:28 PM
jampg's Avatar
Have you guys played with the rear spring tension at all?
Old Oct 10, 2006 | 09:34 PM
I haven't played with the tension at all. It seems to be right on where it is. It's great in corners, over tree roots, long bumps (yes it will sail if going fast enough), and roads. Even better when the going gets slow, like in rocks, mudholes, etc. I think it comes on the softest setting and I think that is just right. If it were me and someone else who weighs as much as me, I would probably dial it up a couple of notches. The only time I don't like it is in tight whoops. But, it does soak them up very well if you stand and let the machine absorb the bumps.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
